Hi,
I really and genuinely hope you can help me with this problem.
I have a Fujitsu Siemens Scaleo P which we bought in 2005. It has the following specifications:
- Intel Pentium 4 HT 530 Processor @ 3 Ghz (but CPUID shows it as 2992.8 Mhz :S)
- 2.5 GB of DDR2 RAM
- 160 GB Hard disk
- Asus P5GD1-FM/S Motherboard
- ATI Radeon x300 128MB Graphics
Recently, the computer started restarting on its own, and it seemed random at first but then I noticed that it would restart on load. So, I changed the stock intel cooler and replaced it with the Scythe Samurai ZZ Fan - I am sure I have done it right as the temperature seems to be around 56-57 degrees C on no load.
But it carried on restarting, so I formatted the hard drive 3 times and loaded Windows XP and Windows Pro and Ubuntu and the problem still remained. Then I have added the Akasa Quiet Case fan, and after no restarting for a day, it has started to restart again.
I have checked the RAM using memtest86+ (all clean) and took the RAM out and cleaned them as well.
Please help as I literally have no more clues as to how do I fix this problem.
I am fairly computer literate - I use Ubuntu 64bit as my OS on my laptop (okay, not so much computer literate then!!)
Thanks and regards,
Mrinal
- 160 GB Hard disk
Thanks and regards,
Mrinal
