Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Old 8800GTX reference cooler maintenance
Forum Graphic & Displays : Graphics Cards - Old 8800GTX reference cooler maintenance
Hello!
Just got a used 8800gtx from fleabay, its one of those EVGA gateway edition ones, with the funky looking reference cooler.
anyway while inspecting the card i noticed the heat sink plate has separated from the VRAM so it's not touching all the chips, It has spring loaded bolts thought.
I can clearly see a space between the chips and the heat sink, is this normal and expands with heat?
Or do i need to remove the whole thing and re-seat it and add compound or tape?
cause the latter would suck... :cry:
Sponsored Links
If it was me I would do the latter. I don't know much about the reference cooler you speak of as I have the 8800GTX ACS3 version with the special cooler setup. Whoever had it before you probably took it off to mod it with another heatsink.
Wait and see if someone else posts that knows of this specific unit just to be sure...
------------------------------ EVGA 780i mobo | EVGA GTX 275 | Q9550 OC @ 3.6Ghz | 4G 1066Mhz Corsair Memory | Corsair 1000 watt PSU | Coolermaster Stacker CM830 Case | Ultra TEC CPU Cooler | Vista Ultimate 64
Reply to englandr753
Hmm... i doubt the previous owner removed the original cooler since the warranty sticker is intact and fully covers one of the bolts, provably caused by the ludicrous temps the 8800GTX's normally run at.
The cooler looks similar to the BFG,ASUS,XFX one for the 8800gtx but it has a slightly narrower exhaust shroud.
can compound be substituted for the normal thermal tape that goes over ram or should i stick to tape?
Reply to Mugen-G
Compound should be fine just be sure to use a high quality compound and evenly apply to ensure proper coverage.
There are 648 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
