Tom's Hardware > Forum > Homebuilt Systems > New System Build > Q8400 system, any possible problems
Forum Homebuilt Systems : New System Build - Q8400 system, any possible problems
I'm about to go out and buy my new system parts.
Just wanna check if i've missed something.
ASROCK G31M-S
2gb ddr 800
9600gt
Q8400
OCZ stealthxstream
1 dvd rom drive
1 320 Gb sata HDD
Just have a quick look if you can, is there something apparent that i've missed.
Also any improvements or ideas you'd like to add.
Thanks
Funu
Sponsored Links
Those aren't really "new parts."
Check the form in my sig and we'll help you build a much better system.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Might be nice to have a case to hold all that stuff.
Reply to WR2
How much are you paying for those parts?
Reply to WR2
Well i already have everything, was just going out for a new Q8400 to replace the P4 ive been using for the past 9 years -_-"
But to your question, I already have a case, i dont need to factor that in.
I'm paying 110 Euros for the CPU - which seems like a good deal to me
Reply to funuraba
Was the QQ8400 on the CPU support list for the ASROCK G31M-S?
Reply to WR2
Umm, what exactly is your question, now that you've wasted your money on a last generation build?
Reply to jbakerlent
You can go out and get your parts.
Reply to WR2
There are 954 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
