Problem with 320GB SATA HDD
how would i know that my computer supports 320GB SATA HDD?
3 answers Last reply
More about problem 320gb sata
  1. There is no limit to what your PC can support. It will support till you run out of SATA sockets!
  2. As long as your motherboard is not old enough to not have a SATA port.
    As for the capacity, there's no actual limit on that.
  3. What you DO have to worry about is the Version of Windows you are running.
    Anything prior to XP SP1 will only be able to use 127gig, no more.
CPUs SATA Computer Hard Drives
