Tom's Hardware > Forum > Graphic & Displays > Nvidia > Dual DVI on W7 = problem
Forum Graphic & Displays : Nvidia - Dual DVI on W7 = problem
Hi all
I install Windows 7 on my system:
MSI K-Neo4f
AMD 64 - 3600 x2
3GBram
Gigabyte NV 8600 GT 512ram
LCD 20" connected to primary dvi port
Projector InFocus LP120 connected to secondary DVI port
And i can`t get picture on My projector connected to second DVI out
in all configuration - Extend Desktop, Clone Desktop, One Desktop etc
also i try swap DVI cable, and DVI ports
one result - Projector say - "No signal"
I try drivers for Video card:
-original W7
-Gygabyte Drivers
-Nvidia drivers
no result :(
on second system (Vista)
with Gygabyte drivers - projector work good
Sponsored Links
Try uninstalling whatever driver you're using now and install the latest drivers from www.nvidia.com. Did you Also, is the monitor and the projector connected before you boot up the computer? Is the Screen Resolution panel showing both monitors being detected?
Reply to skolpo
System detect all attached device correctly (Name, resolution, etc)
but i see in panel wrong type of port for Projector
connected to DVI - show as connected to VGA
http://keep4u.ru/imgs/s/2009/11/04/b3/b3649b66c1bace769dbd4f638892fd1d.jpghttp://keep4u.ru/imgs/s/2009/11/04/0c/0c2fc198c9365b60cc2e2c7b71958ab4.jpg
Reply to Sandr
i try from Nvidia site, lates Stable (192) and Beta (195 - 30.10.2009)
Reply to Sandr
Have you tried using the Display properties from Control Panel and activating the monitor(s) from there?
Reply to skolpo
Yes, Projector activated in both panels:
-Nv control panel
-System CP
I have long used this configuration in Vista - in Vista and W7 Configuration panels look the same
Reply to Sandr
FIXED
answer in Type of connection detected by driver/system
need DVI
detected VGA
I opened the DVI plug on cable to projector
this cable is DVI-I (analog+digital)
and cut the analog wires
Quote :
C1 Analog Red -- -- -- --
C2 Analog Green -- -- -- --
C3 Analog Blue -- -- -- --
C4 Analog Horizontal Sync -- -- -- --
C5 Analog GND Return: (analog R, G, B) -- -- -- --
http://keep4u.ru/imgs/s/2009/11/07/e6/e683abdf64d17e20271c63a6218da5bc.jpg
Projector work good :)
Reply to Sandr
There are 623 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
