hello there im building a new gaming computer that i want to last 5 years or so without upgrades "except the gpu im fine with that" anyways along with what i am building i plan to put it in a
Rosewill Thor V2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
$130 which is good for full atx gaming case
Along with that the thor has alot of fan options
im keeping the front 200 mm fan just becuse i dont feel like replaceing it
i also may keep the back 140mm fan if its quiet enough and has enough cfm for my likeing
well onto the parts that im decideing to change
well first on the side panel of the thor there is an option to put 4 120mm fans and i was thinking thee
coolermaster sickle-flow red led
70 cfm
19 led
long life sleeve bearing
2.94 mm/h20 static pressure
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103091
these will be mounted vertically as all sleeve fans should.
are these quiet? and how long do they last?
well on to the cpu cooler
i want to get an corsair h100 just for the fact better cooling than nh-d14 and it does not obstruct the airflow but i have low profile ram if i want one i can get it
which i will if
1.is the corsair h100 too loud "will be replace the fans with some others"
2. does the noctua actually obstruct the airflow?? plus will it damage my mb?
well onto the fans for the corsair h100, or just for the top part of the case in case i dont decide to get the h100
well i thought these are good since i cant use sickle flow for these since they are sleeve
MASSCOOL BLD-12025V1R $8.49 since ill probally get 4 for my h100
60cfm
23.5db
ball bearing
1500 rpm
2.01 mm/h20 static pressure is that good enough for an h100??
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150117
are these good enough fans for the h100? will they be loud? enough static pressure? enough cfm??
and on a side note when i get bored of waiting for ivy bridge to come out i may make a mode to the case so i can have 1-2 fans directly blowing into the gpu's fans will this lower a gpu's temp or is it useless??
thank you for your time everyone bye
Rosewill Thor V2
70 cfm
19 led
which i will if
60cfm
23.5db
ball bearing
1500 rpm
