Yes No
Ads
Tom's Hardware > Forum > Overclocking > Water Cooling > Water Cooling Nightmare!
Forum Overclocking : Water Cooling Water Cooling Nightmare!
So I started the install on my brother rasa rs 240 kit today and ran into some trouble..
First off the 5.25" res/bay combo can not be screwed in the proper place without drilling holes into his bays which really isn't a big deal BUT we ordered 1/2" ID UV Acid green tubing for the kit since the barbs are also 1/2" and with the little plastic clamps that come with the kit we have multiple leaks from the tube to barb seals...
Just looking for some easy inexpensive solutions..for the time being I was thinking just putting in some plumber grade screw tight clamps until we come up with a better solution. As far as the bay mounting I see no other choice then to drill holes to accommodate the bay/res.
Reply to mtech23
can you post pics of the rez, i don't 100% follow what u mean there.
as for the leaking. i try to stick away from barbs, i use compression fittings.
being you have the barbs you can try some Hose clamps. they can be done as tight as anything and will make a good seal. they are also cheap as.
http://www.google.com.au/search?q= [...] 36&bih=805
your local hardware store should have them at about $0.50 each.
------------------------------ 2700K @ 4.5 | Maximus IV Extreme-Z | 16gb RipjawX DDR3 1866mhz | 2x 2GB 5870's | Eyefinity @ 5760*1080 | 2x WD Black 1TB Raid 0 | EK&XSPC Water Cooled | Thermaltake 1200w PSU | Thermaltake Tai-Chi Case
No liability accepted or warranty given for advice
Reply to hugostiglitz
Use your/his drive mounting rails to mount the res, if the case has them ofc, I had a similar issue and used the hdd rails from my dragon rider, as the pegs on optical driv rails are offset and won't fit
And yes the wormdrive clamps are fine, just don't over tighten,
Moto
------------------------------ Once you start watercooling, you are almost automatically inducted into the modding circles as well, because theres rarely a 'from the box, fits everyone' solution, its your ingenuity and resourcefulness that makes it all happen,
Reply to motopsychojdn
Quote :
Here is your problem- Rasa kit fittings are 7/16"ID not 1/2"ID. Running too large of tubing on smaller fittings never works. You can run smaller tubing on larger fittings if you do it right.
------------------------------ Watercooling Info:
Tom's Hardware Watercooling Sticky
Build Log | Project: Askew
Stuff 4 Sale
Reply to rubix_1011
There are 2078 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 12 hours ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
