Tom's Hardware > Forum > Homebuilt Systems > New System Build > Audio question for new HTPC build
Forum Homebuilt Systems : New System Build - Audio question for new HTPC build
Hi,
I am looking for info and advice on a HTPC build related to audio. I bought recently a nice set of speakers (5.1) for my home theater and I also got a decent yamaha receiver. I love music and look forward (among other things) to playing my itunes library on my new stereo equipment.
When I build my system I have the option to use the onboard audio on the Mobo or buy a sound card, say like an Asus Xonar 1.3. For regular PC use I can see why having a sound card is better than onboard audio. The sound card does the digital to analog conversion to drive the PC speakers better, for various reasons like better filtering, SNR etc. Plus it offloads the CPU some with audio work. But for a HTPC build, if I send a digital stream to the receiver, the receiver is doing the digital to analog conversion, and will do a quality job. Am I right in this assumption? Will there be a discernable audio quality difference between onboard and discrete audio for this case?
I am looking for quality, but if there isn't much difference it would be a shame to buy a sound card that is not needed.
Looking for help, thanks
Jim
Sponsored Links
I'm a little confused by your post, but I think you're asking whether a sound card improves sound quality and/or system speed.
The answer to both is yes, but both are generally negligible - I'd just stick to onboard.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
+1 jbakerlent. For most people, onboard is plenty good enough. If you find that it's not what you need, you can always buy a card and upgrade.
------------------------------ Antec 900, MSI P7N Diamond, E8400,
4 GB (2 x 2GB) Crucial Ballistix 4-4-4-12, 8800 GTS 512 SLI
Reply to huron
There are 486 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
