Tom's Hardware > Forum > Graphic & Displays > Nvidia > BFG nVidia Geforce 9500 GT MAJOR problems
Forum Graphic & Displays : Nvidia - BFG nVidia Geforce 9500 GT MAJOR problems
Hey, I have a windows vista. With 2 gigs of ram. i got a AMD athlon 64 x2 duel-core processor 4000+ 2.1 ghz. I have a BFG nVidia Geforce 9500 GT. it was upgraded from a onboard 6150 LE Nvida Geforce. I have had my 9500 for almost a year and The fan has gone out on me. When ever i play any kind of games the tempertor rises significantly and this is what happens. The monitor goes on standby and the computer stays on. Iam forced to restart after that. When i play around with the fan wile my pc is open it will start to power up for about 2-3 seconds then stop again.
My question is Can i fix this problem without spending money on a new video card?
Can i take a fan off a radion 9550 ATI 256 MB Vram and put it on my Video card some how??
Thx for reading this.
Sam :)
Sponsored Links
A cheap zalman vf-700 or 900 if you can get it cheap. Both can easily cool higher end cards with headroom for oc.
Reply to nforce4max
Try to clean the dust on the fan.
Your card should be under warranty...
Reply to shubham1401
^ +1
Clean it using compressed air NOT a vacuum.
BFG has a good warranty I believe.
------------------------------ EP-45 UD3R/ E8400@3.6 wZerotherm Nirvana/4gb Corsair DDR2-800/EVGA 9800GTX+/Corsair 750TX/2xWD Black AALS 640gb RAID 0+1 Windows 7/2xWD Cavier 250gb RAID 0 Windows XP Pro/Seagate 160gb Backup/X-Fi Xtreme Gamer/Logitech Z-2300/Samsung SynchMaster 906BW
Reply to anort3
A $5 case fan, a few small pieces of cardboard for mounting and alignment, and rubber bands will also work as a replacement GPU fan.
Reply to HundredIslandsBoy
After you clean off the dust and gunk and it still fails, squeeze one drop of machine oil into the fan bearing. Worked for me on an old Artic Pro Freezer 7!
There are 497 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
