Archived from groups: comp.sys.laptops (More info?)
My 18 mo. old R32 is plagued by lockups and flaky DVD access. It also has
difficulty shutting down. A complete reformat/reinstall of the OS made no
difference, so I am now considering replacing the system board. I found a
vendor online with it for $500, and I get $50 back if I ship them back the
old one.
I've put desktop systems together but am a little intimidated about cracking
open the laptop. I found a hardware manual at IBM support, but it's not
very detailed.
Is this a no brainer not worth getting worked up about? Any opinions about
whether this will fix my problems.
> old one.
> very detailed.
Hi,
B4 doing that, what sort of hardware/system diagnostics have you run?
Tony
I ran PC Doctor (IBM's diagnostic program). It showed no problems other
than failing to access the CD/DVD drive.
"Tony Hwang" <dragon40@shaw.ca> wrote in message
news:s0cyc.727976$oR5.305742@pd7tw3no...
has
no
a
the
> > old one.
cracking
> > very detailed.
about
> Hi,
> Tony
"Wesley" <wesleyf@portablecomputer.com> wrote in message
news:cee41efe.0406110623.2598091b@posting.google.com...
> Our company does flat rate board level repair for $295 and we provide
> a 6 month warranty. Please check us out before spending $500 on a new
> board.
> http://www.portablecomputer.com/re [...] ration.asp
Dave,
Did you ever get any resolution on this? I just bought a used R32 and
no less than 24 hours after getting it I've screwed it up in a failed
BIOS upgrade attempt. Did you go with portable computers? If so,
how did it go? Or find better solution?
Any help you can throw my way is much appreciated.
Dan
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
"Dave Morrell" <nospamdmorrell@mail.com> wrote in message news:<2iu6pfFrh58uU1@uni-berlin.de>...
> > board.
> > http://www.portablecomputer.com/re [...] ration.asp >
> What turnaround could I expect?
If you know how to put a dektop together from components, you can
replace the system board on a thinkpad. I was nervous too, but the
manual from IBM was enough for me. I don't know about R32 system
boards, but I know there are boards for other laptops on eBay. You
could try looking there and doing it yourself.
