Will this meet my HARDCORE gaming needs? good value? i am building myself, buying off centrecom.com.au as you may have noticed, as i live in melbourne australia. How long with this last me? is it upgradable in future? Yes, i look to constantly stay with the newest games.
Also, are these compatible? measurements and all? sorry, im not very computer savvy. if not, could you please suggest another component/s from CENTRECOM.COM.AU, that is not more expensive...
The i7 920 is all you need. At half the cost, you'll get just as good performance, especially with a conservative overclock. You can then spend your money somewhere that will actually make a difference.
If you are buying just one 5870, that should work well on a 1680x1050 monitor for a few years. If you are buying two, that would probably keep you happy on a 1920x1200 monitor for the next three years.
The CPU and motherboard will probably keep you satisfied 3 to 4 years. If you upgrade the CPU in two years probably 5 total.
thanks so much. um, im not sure about the monitor, but thats something for me to figure out. out of everyone on thus site so far you are the one who has helped me the most!! thank you!!!
blaaarrrggggg the ThermalTake V9 case sucks so bad - a cheap generic copy of the Antec 900
to anyone else looking at getting the V9 - after a month the fans start rubbing on the chassis and the mesh up top bow's - rubbish case
also dont get a "green" (power efficent, low performance) drive - from the money saved going to a 920 CPU spend it on an SSD and then a basic drive for storage (even a "green" one)
Sound cards don't really have any DX limitations that I have heard of. Onboard works fine for most people.
I personally own an X-fi but that's a matter of preference and possibly because it makes my Klipsch speakers sound better.
I didn't comment on either the case or drive specifically, but you'll see I changed both in my list. Apache_lives has good points. I don't have any direct experience with the V9 that I recall, but I can see easily that it's inferior. Very cramped interior.
I own a high end Silverstone case, but I recommend mostly Cooler Master, NZXT, or Lian Li. They tend to have more room for the longer video cards.
An SSD can be a nice edition to a build, but is not so urgent if it puts you over budget. I listed a Caviar Black 1TB as it's a fast drive at a good price. A good SSD will be about 2.5 times faster and about 4 times more expensive and about 1/10th the volume
Start with the graphics card, which is THE most important part for gaming. The 5870 is about as good as it gets. Start with that. Over time, there will be faster, cheaper, and better cards available, so dont expect to be using it forever. If you find it lacking, then you can either add a second in crossfire, or you can sell it and get the next best thing. A 5870 should give you very good gameplay at 1920x1200.
The i7-950 is a great chip, and is guaranteed to be a D0 stepping which overclocks better than the original C0 steppings. If you can get a guaranteed D0 stepping i7-920, then save some cash and go that route. You can count on an easy 3.2 overclock with no voltage increases on either chip.
Don't pay extra for a enthusiast X58 motherboard unless you are a competitive overclocker. Any good quality X58 motherboard that has the features you want should be fine. Look to EVGA,ASUS, and gigabyte for starters. With a X58 motherboard, you will have the option to upgrade to the next 32nm 6 core chip from Intel. I don't forsee the need for that for gaming.
Use the onboard HD sound, at least initially. It is very good, and you can always add a sound card later.
6gb of ram is about right. The nehalem memory controller is very good at feeding the cpu. Don't pay extra for speeds faster than 1600, or better timings. It will not translate into any meaningful increase in FPS.
I would agree with the WD caviar black 1tb recommendation. It is almost as fast as the velociraptor. SSD prices are coming down, but they are not yet a great value. If you have the cash, consider one for your OS and program drive. Look for one with TRIM support like the Intel X25-M G2.
Go ahead and get windows-7, probably home premium. It has the aforementioned TRIM support. If you are a student, look for a cheaper academic license.
A case is a personal matter, and most cases will do fine, just so long as it has two 120mm input fans and two similar output fans. I might suggest the Antec 300 illusion model, or the Antec 902.
The corsair 850 is good enough to handle two 5870 in crossfire, and is a quality PSU. If you will never have more than one card, then you can pay less for a 550-750w unit.
---good luck---
Message edited by geofelt on 10-27-2009 at 03:47:29 PM
