I7 920 temps with stock cooling + stock thermal
Last response: in CPUs
- best settings in bios to lower core i7 920 temps with stock cooler - Forum
- I7 920 stock cooler thermal pads or compound? - Forum
- OC i7 920 + Asus P6T (Stock cooling) - Forum
- Overclocking to 3.4ghz on stock cooling on i7 920 D0 ok? - Forum
- Zalman cnps 9900 temps on i7 920 stock speed - Forum
- SolvedAre these temps ok? (Core i7 stock cooling, 84 degress on full load) Forum
- How high does the i7 920 with stock cooling get??? Forum
- Core i7 920 @ 3.33Ghz - Stock Cooling? Forum
- SolvedI7 920 stock fan real temp 3.4 test results NEED HELP Forum
- i7 920 / 212 evo - stock settings Prime95 temp Forum
- SolvedCore i7 4790K High Temps + Weird Marks (Stock Cooler) Forum
- Solvedi7 920 stock fan? Forum
- Q6600 Thermal problem cant oc(stock Temps too high) Forum
- SolvedWhat cards will a i7 920 at stock 2.6GHZ start bottlencking. Forum
- Solvedi7 920 stock To i7 4770k or overclock for 2014+ gaming? Forum
- Solvedi7 4770k same temps stock-4.2GHz!?!?! Forum
- Solvedi7 3930k stock temps? Forum
- Solved4.3Ghz to 4.5Ghz? (OC + Temps on Stock cooling) Forum
- SolvedUpgrading from i7 920 stock to OC 2500k help Forum
- SolvedHigh Temps w/ stock cooling Forum
- More resources
