Folks, I really need help on this one. A co-worker of mine just got a Dell computer with an Nvidia Quadro NVS 420 and it will NOT go past 1200 X 800 on his 30-inch Dell monitor.
I have tried a number of things but nothing has worked thus far.
FYI. it'll work on a 19-inch monitor and get me 1280 x 1024
Any suggestions?
------------------------------ASUS PQ5 PRO - E4500 @ 3.3 - 4GB GSkill DDR2 800 @ 4-4-4-10 - Sapphire 4850 512MB @ 655/1015 - Western Digital Caviar Black 640GB 7200 RPM 32MB - Win 7 64-bit - PC Power & Cooling S61EPS 610W Power Supply
Have you tried the newest card drivers and monitor drivers if available? What type of cable are you using? Could also try contacting Dell if it is a new system (probably worthless, but who knows, maybe they know of a bug with their systems).
------------------------------Phenom II X4 940 BE 3.0GHz - 1.25V > GA-MA790GP-DS4H > XFX ATI 4850 1GB > 4GB OCZ Platinum 1066MHz 5-5-5-15-2T > PCP&C 610W
Athlon II X2 250 3.0GHz > GA-MA770T-UD3P > Sapphire ATI 4650 512MB DDR3 > 4GB OCZ Platinum 1600MHz@1066MHz > XP/Win7 Enter 64
Reply to EXT64
Thanks for the fast response. I have indeed tried the newest drivers, i'm running Win 7 Ultimate so i figured i would try the Vista 64 drivers as well, but that didn't work. I also slapped that card into a machine with Vista installed and added the latedt Vista drivers and still the same result.
Tried to contact dell and forget about that, they're horrible.
As for the cable, i'm not entirely sure, it's a weird adapter to the video card itself, and then the adapter has 4 DVI ports to connect up to 4 monitors...
Reply to jonpaul37
