Decryption problem
Hello,
sir i have encrypted my images folder in windows xp..but then i change my windows from xp to seven..now i am trying to decrypt my folder,but it gives the error..plz give the approprite solution.
i am very thankful to u for this.
1 answer Last reply
More about decryption problem
  1. this is what microsoft say
    The first time you encrypt a folder or file, you should back up your encryption certificate. If your certificate and key are lost or damaged and you do not have a backup, you won't be able to use the files that you have encrypted.
    do you have the certificate and key
Security Decryption Windows XP
