Solved
Hp dv6 6135dx with 6755g dual graphics problems?
When I first got the pc I did a minamal recovery to get rid of the bloatware,however when I did this I was no longer able to access amd vision engine control center to make adjustments to my graphics cards. This system uses the 6620g along with the 6750m in crossfire, however microstuttering is a problem on some games and I would like to turn cf off.I've tried driver sweeper to no avail.Under list of programs no software is listed for amd,however under gpuz it states driver version 8.900.7.0, is this the best version,and why don't I have acccess to catylist control center? I went to hp website after I did the recovery and installed the latest drivers available and most games run fine, however I still can't access ccc to make adjustments?
2 answers Last reply Best Answer
More about 6135dx 6755g dual graphics problems
  1. Best answer
    C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\ccc. run ccc to open catalyst center then under preferences in upper right hand corner check "enable system tray menu".
  2. Best answer selected by jijoslin.
Graphics Cards Data Recovery Hewlett Packard Overclocking
