Little temp-sensor thing for cooling fan
homerjsim
7
Hi
I'm not sure this is the best forum for this, but I'm wondering about where and the best way to attach the little temperature sensing ribbon thing on my 2 front cooling fans - it's on a thin wire coming from the fan, and I was going to wrap that around some cabling and let the ribbon end-thing kind of flop around a little, but I'm thinking that's probably not so good. I could cable-tie them to some other cables, but then they're not close to the CPU, RAM or chipset. Does that matter? Any advice?
Thanks in advance!
pluke the 2
352
Pix brother!!! And use paint to edit them as Jpegs, explain in your picture a before and after, so that we could answer your question best! "Also link your temperature sensing ribbon thing" lol.
homerjsim
7
ok here are my two little temperature sensor ribbon things, held above the power supply (they're for those two fans in the front). this is a micro case, btw. (I'm thinking some kind of heat-resistant tape, just wondering how close they need to be - I mean, the CPU already *has* a cooler and fan...
