Help, need a case and PSU for GA-EP45-UD3R+Q9550
Last response: in Components
Anonymous
Power supply Expert
There are so many different types of cases and PSU's out there, so I am totaly confused. I am leaning towards a mid tower case but have no idea will that be big enough to provide sufficient cooling. Do you think 650W of PSU if I decide to overclick later. Thank you for your ideas!!!
Anonymous
Power supply Expert
I haven't got video card yet, only the cpu, mpbo and G.Skill 2x2GB DDR2 1066Mhz. I do dot play a lot of games so it should be a middle range Video card.
Related ressources
Anonymous
Power supply Expert
The antec 300 is a good looking one although its too big for me , I only live in one bed flat, so no much room. Do you think Thermaltake M9- Mid Tower is going to be fine for this configuration?
zzfh is right, a mid tower case is a mid tower case, usually the sizes are non-negotiable. the Antec is a great case, i just suggested mine because it REALLY is a great case and it's something different other than an Antec that everyone usually recommends.
Anonymous
Power supply Expert
Thanks zipzoomflyhigh for the advice. I will probably stick to Antec case. It is good value with plenty of scope for upgrade, olso, a good looking one. How about the OCZ PSU, do you think 550W is suficient if put under extra presure when overclocking? From the staff I read elsewhare I have an impresion that the bigger and most powerful the SPU is the better.
some PSU's are built better, this means that a 550w PSU from OCZ or Corsair will be better than a 650w PSU from a no-name brand. There are a lot of factors that play here, like amp rating on the 12v rail, 80+ certified, etc...
To answer your question, the OCZ 550w PSU will handle anything you throw at it if you are using one video card, and in most cases, it will handle a 2 video card solution.
Ask the community
