Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Can dvd burner be on a split sata power cable with hard drive
Forum Homebuilt Systems : General Homebuilt - Can dvd burner be on a split sata power cable with hard drive
I am having problems with my dvd burner and dvd rom drives. My most used dvd burner is on the same sata power cable as my main hdd. The dvd burner used to make my computer run very quirky and slow when it was in use. Now the dvd drive has gone out on me. The dvd rom is on the same sata cable as my scratch disk. It sometimes doesn't want to work well either but not like the primary. Should these drives not be piggy backed with the hard drives? I only have the two sata outs on the PSU.
Beth
Message quoted 1 times
Message edited by Anonymous on 10-29-2009 at 06:10:32 AM
Sponsored Links
Beth
There should be no reason that you couldnt piggy back them. Unless the power supply is underpowered!
Case: CoolerMaster Centurion 590
PSU: ThermalTake PurePower 500W Rev. 2.0
Reply to BigFysh3
There are 517 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
