hi my name is nilesh
i will build a game system in dec 2009
right now i am so much confuse i was planing to buy i7 gaming system but i listen that dx11 card & i9 will launch soon so what i do plz suggest me a best gaming pc confrontation so can play game at least 5 year without upgrading i am student so cant able to upgrade it so plz suggest me fast my budget is 45k(approximate 45000/- RS)
i am also thinking about ati hd5770 is this good for me ?
plzzzzzzz help!!!!!!!!!!!
GIVE ME A GOOD GAMING PC CONFRONTATION TO BUILD A GAMING PC 2010
THANK U OR I UPGRADE MY OLD p4 SYSTEM with ati hd 3650?????????????????
As far as CPU goes, any i5 or i7 will probably be fine for gaming for the next 5 years.
As far as video cards go, currently in the US, the best bang for your buck are the new ATI 5850 and 5870. Any video card or system you put together today will likely be lacking in 5 years. PCI-e 3.0 will be out in around 18 months and it will be 2x as fast as the current PCI-e 2.0, so I would expect in two years, there will be games that won't run well on a new system. This is almost always the case with gaming systems. You have maybe a 2 year life span before the system starts being a bottleneck.
i live in India
can you plz tell me which is best gpu in above with price
gtx260
hd5770
hd4770
dh4890
hd4870
hd5870
hd5850
with good performeance
and also i have time time till dec. 2009 so plz give me a good gaming system confrontation
------------------------------You can select me as Best Answer e6400 oc'd 3.2ghz,CCF cooler
3870x2, p5k/epu
750watts psu, antec 900
Reply to overshocks
