Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Problem with monitor or graphics card
Forum Graphic & Displays : TV/Video Cards - Problem with monitor or graphics card
Hi! Yesterday a friend of mine gave me his old desktop,basically only the pc tower. He warned me that the pc is full of viruses and asked me to format the disk if possible. now the problem is this: when i connect the monitor and power up the pc, the monitor doesn't respon't at all! it is like i haven't connected it to the pc. I checked the cables and they are all in place. So I suspect that there must be a problem with the Graphics card. I checked the monitor to an other pc and it works fine! what can I do to find out where exactly is the problem? thanks for your time!
Sponsored Links
Does the PC (tower) turns on or it does not?
Reply to play_chess23
Yes the pc tower turns on but the monitor displays something like "no input signal,monitor going to sleep"
so i assume that there is no communication between the motherboard and the monitor.but i don't know what to do. If the monitor doesn't respond how can i communicate with the pc? :-)
Reply to DeepBlueSomething
This checklist has a lot of troubleshooting ideas for your problem.
http://www.tomshardware.com/forum/ [...] t-problems
Start with ruling out the RAM as the problem. Faulty RAM often causes a "no video" problem. Try each stick of RAM by itself in the first RAM slot.
Reply to shortstuff_mt
try what shortstuff_mt suggested (checking on ram)... you can also test the ram on another PC and try to see if it functions. Also if you have an extra video card (functioning) try using it on that PC try to see if there is no display...
Ok shortstuff_mt and play_chess23. Thank you both guys for helping me. I ll try to find out if the RAM is the culprit and I ll let you know.
There are 551 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
