Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Power Supply
Forum Homebuilt Systems : New System Build - [Solved] Power Supply
Best answer from tecmo34.
I bought RX-530SS power supply for my new PC. I was trying to check before installing. But by switching ON, no light or power supply's fan moving. Does this mean power supply is dead? or.....
Your PSU won't kick on until you press the power button on the case, with your PSU connected to your motherboard. By turning the switch to on, you have just provide power to it.
You should be okay, unless it does the same thing when connected to your motheboard.
edit: dndhatcher beat me to it...
Sponsored Links
It wont turn on if its not plugged in (to the motherboard).
Raidmax is not a quality power supply maker.
Reply to dndhatcher
Best answer
Message quoted 1 times
Message edited by tecmo34 on 10-30-2009 at 02:07:13 AM
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Finally I got one in before you. :lol:
Reply to dndhatcher
There are 763 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
