Overclocking Need Help!
I just built a new gaming system and I am having some issues with overclocking.
Setup:
i5-2500k
asrock extreme3 gen3 z68
corsair 850txm
8gb 1600 ram (corsair)
corsair h60 (not push pull yet need the screws to make it work)
haf 922
1tb hard drive
I am no overclocking pro, this is my first exploration into it besides for pressing the oc genie button on my msi board. I have done my research and have explored several differant sites looking for info. Most say I should be able to easily attain 4.5 with about a 1.25v oc however im running into some issues. It seems to be able to stay stable, already moving up to 1.285v and still not getting stable at 4.5 I'm not sure if this is normal or if I'm doing anything wrong. My temps still haven't gone past 50c but I have only been able to run prime for a few seconds due to it shutting down. Any help would be awesome.
Setup:
i5-2500k
corsair 850txm
haf 922
1tb hard drive
More about : overclocking
im not a pro either and am having my own issues, but I have heard people say lower the CPU PLL a little and it can help stabalize an overclock. I think stock is like 1.8 and lower it to 1.791? Just 1 or 2 clicks down on that board, i have the same board, my issues are that i keep getting random power outtages, i hope my board isnt bad =[
i had my pll down to like 1.71 or whatever was the one closest to 1.7. I heard some people were having issues with this board and I hope mine isn't a bad one. I don't know if not having a graphic card effects it or anything since it will arrive tomorrow. I put in quite a bit of time trying to figure it all out but I just don't know what to do, even at 1.285 volts a cored instantly errors in prime95. Sometimes on my cpuz it doesn't show my multiplier correctly. I don't know if thats normal or not.
Mine crashes a lot too, im almost wondering if these boards arent bad, and i have not been able to run it stable with anything below 1.3vs, i get blue screens if i have it below that. Same cpu too btw, our rigs are almost identical other than ram and heatsink. my ram is g.skill ripjaws x 1600, and im on a hyper 212 air heatsink
Related ressources
- Need help with overclocking Core 2 Duo E8500 - Forum
- I need some help WITH I7 3820 Overclocking ... - Forum
- Need help on AMD FX4100 Overclocking - Forum
- Need Help Overclocking my GPU - Forum
- Need help overclocking my AMD Phenom ii x4 965 BE - Forum
A friend of mine also had trouble getting 4.5ghz stable on his 2500k. He eventually got it though. He told me that it was one setting in the bios that was stopping him. His motherboard is an ASus z68 gen3, which should be VERY similar to your asrock board. Maximum recommended vcore on air cooling is ~1.4 so don't be afraid to test 1.3, especially since you are water cooled. I wouldn't go too far though, since 4.5 should be pretty easy. I will ask him for you, and post exact settings here soon.
Your temps are good. I think for longevity, most say to keep temps below 70'c and vcore at or below 1.35v. Anything higher will reduce lifespan, but it's not known by how long. 4.5Ghz seems to be the norm, and anything higher is more for bragging rights.
It looks like most 2500k cpus will be able to hit 4.5 pretty easily. But it's the luck of the draw. Unfortunately, there will be a very few unlucky ones (like myself) that will hit the wall and can't OC that much. I can only go as high as 4.3Ghz stable. Anything higher crashes or BSODs. Not able to get past the wall no matter what I do and I've tried for months.
I don't think a better mobo will change anything. It's going to be dependent on how lucky you got with the cpu. The cpu will have certain tolerances and none of us can tell what that will be as each cpu will be different. There are some that can acheive 4.7-5.0 Ghz on very low voltage (below the average) for example. Don't expect you can do the same.
Edit: You can also do IBT ~20 standard passes and ~10 maximum passes to see if you are stable (on top of P95). Sometimes it can detect instability that P95 can't pick up. But it will really stress the system and result in higher temps than that shown in P95.
neograndizer said:
Your temps are good. I think for longevity, most say to keep temps below 70'c and vcore at or below 1.35v. Anything higher will reduce lifespan, but it's not known by how long. 4.5Ghz seems to be the norm, and anything higher is more for bragging rights.It looks like most 2500k cpus will be able to hit 4.5 pretty easily. But it's the luck of the draw. Unfortunately, there will be a very few unlucky ones (like myself) that will hit the wall and can't OC that much. I can only go as high as 4.3Ghz stable. Anything higher crashes or BSODs. Not able to get past the wall no matter what I do and I've tried for months.
hes right. my chip can go all the way to 5.0 all the way with what i believe a little above average temps but none the less it can go to 5.0 but as soon as the multi goes to 51 it will not boot. no matter what i try. disappointing cause i really wanted to get a 10 in cinebench.
I now have another question for my own computer. I just got the same h60 cooler using an msi p67-gd65A with an i5-2500k. I am trying to overclock it as well but my temps seem crazy high already. I am only running a 4.5 overclock as well so far on this system and a voltage of 1.3 in bios, but showing 1.375 in cpuz. Just like my girlfriends system I have the h60 only in a pull system and after only 20min of prim my temps are hitting 70-79 which seems a bit high for this cooler, especially since I have another system to compare it too. Even the idle temps before starting the oc seemed higher ranging from 30-40 vs my other one which was sitting right at 28-21.
Crzywhiteskata said:
I now have another question for my own computer. I just got the same h60 cooler using an msi p67-gd65A with an i5-2500k. I am trying to overclock it as well but my temps seem crazy high already. I am only running a 4.5 overclock as well so far on this system and a voltage of 1.3 in bios, but showing 1.375 in cpuz. Just like my girlfriends system I have the h60 only in a pull system and after only 20min of prim my temps are hitting 70-79 which seems a bit high for this cooler, especially since I have another system to compare it too. Even the idle temps before starting the oc seemed higher ranging from 30-40 vs my other one which was sitting right at 28-21.your voltage is too high
adjust cpu ratio OS disabledinternal pll overvoltage enabled
eist enabled
intel turbo boost disabled dram is at auto 1333hz
spread spectrum disabled
vdroop set to low vdroop
core volt 1.33
imit cpuid max disabled
intel c state enabled
package c state limit set to no limit
you said 1.375 and now its 1.33? what is it?
if those are really your settings then it must be your cooler or your case flow. check you have good case flow by taking off the side panel and check temps again.
i said it was set to 1.3 in the bios in my original post but the core voltage in cpuz shows higher. The side panel is already off and I am using a haf 922 so my case flow has always been good. some people have said with the h60 if its mount badly it won't work, but I just mounted one without issue so i don't think it could be that.
Related ressources:
- ForumNeed some help overclocking cpu/nb 965
- ForumI need some help /advice overclocking my rig please
- ForumNeed help overclocking my msi7970 oc edition..
- ForumNeed help overclocking on msi-g46!
- ForumMSI overclocking , need help , MSI R7770-PMD1GD5
- ForumOverclocking , need help with DRAM Frequency
- ForumNeed help overclocking AMD CPU
- ForumNeed help With Overclocking
- ForumNeed Help Overclocking My Friends Phenom II X6
- ForumNeed help overclocking i7 3770k
- ForumNeed help overclocking intel r core tm 2 duo cpu t9600 2.8 ghz
- ForumNeed help overclocking intel core i7 2600 NON k
- ForumCPU fan clicking?
- More resources
Read discussions in other Overclocking categories
