Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > [Solved] HOME-BUILT SYSTEM -- DUAL MONITOR PROBLEM
Forum Graphic & Displays : Graphics Cards - [Solved] HOME-BUILT SYSTEM -- DUAL MONITOR PROBLEM
Best answer from WR2.
I have built a modest system around an ASUS P4S800D-X motherboard. It works fine and is sufficient to my needs. I would, however like to utilize dual monitors for a number of reasons. OS is WinXP Pro SP3.
The problem I'm having is getting 2 cards to work together. I have several ATI PCI cards that all work as a lone installation, but stop working when the second card is installed. I do not currently have an AGP card to try in the mix......could that be the answer? Perhaps I need one AGP and one PCI???
Any help appreciated.
Thanks,
Butch
You can use both.
Radio Shack has the DVI to VGA adapters but they're pretty expensive.
Sponsored Links
Dual monitors = 1 video card. Two video card not usually required.
List your ATI video cards for us.
I'm guessing none of the have 2 video card outputs?
You maybe having a PCI IRQ conflict keeping you from running 2 video cards.
What IRQ are you assigning to your video cards?
Reply to WR2
The IRQs are set to be automatically assigned by the BIOS, so I really haven't checked them. The error I'm getting in the Device Manager for the second card is "This device won't start".
The ATI cards are a Radeon 7000 and a Rage 128 GL........I know, both are older cards, but I was trying to solve the compatibility issues before updating the cards......
Reply to bbutler247
Forgot to include the main Graphics card.......ATI Radeon 9200
Reply to bbutler247
The 9200 has dual outputs, but I don't have a DVI monitor.....both monitors have VGA connectors.
Reply to bbutler247
You can get a DVI to VGA connector for just a few bucks.
Reply to WR2
Something like this AMC DVI-8700 DVI (Male) to VGA (Female) Adapter $3.50
One NewEgg customer review comment: "This turned my GeForce 7800GT card with 1 DVI and 1VGA port into a dual monitor setup for my new VGA flatscreens! I almost purchased a new graphics card with 2 VGA ports, but I got this adapter for a couple bucks instead."
You might be able to pick one of these adapters up at a local Radio Shack.
Reply to WR2
Lemme show my ignorance for a minute.........So, you're saying I can use both outputs at the same time? I always thought they were "either-or"??
Reply to bbutler247
Best answer
You can use both.
Reply to WR2
There are 1048 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
