Would like to get an upgrade for my video card. What is the Max I can use for a card and what would be a good choice? Like to keep cost to $120 mark or less. I play World of Warcraft. At some point I would like to attach to a TV.
DELL Dimension 8400
Intel(R) Pentium(R) 4 CPU 3.40GHz
072 Mb Mem
NVIDIA GeForce 6800 256 Mb PCI
The 350W PSU in your Dell 8400 limits you somewhat. When did you buy that system?
Something along the lines of Radeon HD 4670 or Geforce 9600GT should be OK if the power supply isn't more than 4 years old.
He said he has a 6800 PCI, I don't believe I've seen any 9600GT/4670's on PCI.
However a quick google reveals that the 8400 has a PCI-e slot.
A 4650/9600GSO should be able to max out WoW at medium rez (correct me if I'm wrong). I'm pretty sure any PSU that Dell uses for a P4 can handle a 4650.
I can anwser PCI-e X16 for sure. Have to check on the motherboard. Got the system about 4 years ago. I know I will need to upgrade in a year or two. I can change the power suply if needed. So im going to guess that I'll need to do a lot more if i'm ever going to get WOW in full detail?
You do have a 1xPCI-E X16 slot, but that PSU is going to limit you on a better GPU, such as the 9800. Unless you are going to replace that 350W unit, I would second the 9600GT, if it requires a minimum 350W PSU like the 9500. This should get you by and perform without spending more money on a new PSU.
Message edited by deadcell on 11-09-2009 at 05:02:18 AM
If your options are PSU limited, then the HD4670 and even HD4770 would require less power than the F9600GT, but the HD4770 would be wasted on something like a P4, and you're paying a premium for it.
And while you could get something now and then use it in your upgraded rig later, I would recommend instead of wasting money on and HD4770 or HD5750 now which are still a little pricey IMO, I would get the HD4670 now and then take the savings and upgrade later to something better as a whole system upgrade once you've tried the HD4670 in the new rig.
Would like to get an upgrade for my video card. What is the Max I can use for a card and what would be a good choice? Like to keep cost to $120 mark or less. I play World of Warcraft. At some point I would like to attach to a TV. DELL Dimension 8400 Intel(R) Pentium(R) 4 CPU 3.40GHz 3072 Mb Mem NVIDIA GeForce 6800 256 Mb PCI
What resolution do you play at? For a p4 with an unknown PSU a 4670 is probably your best choice.
http://www.newegg.com/Product/Prod [...] -_-Product That assumes however that you have a PCI-E slot on your motherboard. Can you check to make sure you have a PCI-E slot and check your PSU wattage while you are in there, if its a good one you might be able to use a 4850.
This next topics has been merged by TheGreatGrapeApe
Best replacement upgrade for Video card
------------------------------You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - REDGREEN. GA to SK HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
Thank you everyone for the responses. I figured that my system is limited by both the power supply and more important the chip set. I guess I just needed it confirmed. Drats! I will do some reading on the HD4670, it sounds like the way to go. I’m sure I will see an improvement in my fps. I just wanted to make sure that I did not waste my money on something that my current system can’t use fully. . Much as I hate to admit it I’m going to half to dig deep and start saving to build my new rig if I want WOW to really wow me.
