I lose sound whenever i use dual channel mode
Anonymous
a b V Motherboard
April 28, 2010 9:46:10 AM
Hello,
I recently bought a couple of Kingston 2 gig ddr2 rams. They are of the same model, same speed and from almost the same batch. Whenever I use both of them I always lose my sound. They work fine when used in singles. I'm on windows 7, motherboard is MSI K9AGM2-FIH. What should I do?
a b V Motherboard
April 28, 2010 2:39:17 PM
I think you know the drill... If you want to use dual channel buy a matched set of ram... Now that you are in this boat I would check your ram voltages and may try uping them a pinch.
m
l
