Closed
Building low noise PC
My goal would be to have a low noise pc with 1, 2 or 3 GPU's.
My options are to either use a modified Haf932 or Fractal R2.
If I choose the Fractal R2 I will either have to use 2 GPU's and a AX750 or replace the fan in my noisy 1000w Golden Green for 3 gpu's.
With the Haf932 I also have the option of using 2 Psu's a HX650 and AX750.
http://i261.photobucket.com/albums/ii50/blundnec/th_IMG678.jpg
http://i261.photobucket.com/albums/ii50/blundnec/th_IMG675.jpg
4 answers Last reply
More about building noise
  1. Components I own:
    Low noise PSU's: AX750, HX650, TX650.
    High noise PSU's: Golden Green 1000w.
    GPU's: 7970, 7950, 7950.
    CPU: X6 1045t.
    I also have a Fractal R2 with socket 1155 system for one PCI-e but I would eventually have to upgrade to a i5 CPU if using a AMD 7900 GPU as it currently has a G620 which is a bit weak.
  2. also for quietness you can purchase sound dampening material to put on large surfaces inside your case. it is very cheap and surprisingly effective. its not something i see done often but it does work. a few sound boards were recently installed in my school cafeteria and took the sound level form ear drum-bleeding to a low din.
    I have 2 Fractal R2 both come with noise dampening from stock, it's called Bitumen I think it's 2mm thick.
    My surfing PC has AX750 psu which propably is passive most of the time as my system is below 150w most of the time.
    Also I have 2 mechanical harddrives and a OS ssd disk, I have one 500rpm scythe sliptream fan as intake bottom fron and one 500rpm as exhaust.
    I can run it passive with Scythe Mugen but I decided to put a 500rpm on it aswell.
    I can't hear anything in it unless there is heavy load on the mechanical drives then slight noise.
    In fact the only source of noise is my Display which has coil whine.
  4. Closing per OP's request.
    PM me if you need it reopened to choose best answer.
Water Cooling GPUs Green Fan Overclocking
