Solved
Fixed Mode or Offset mode Question
Hi everyone ,
wanted to know the differences between these option and the one that is better to use for a 24/7 OC
found out that 1.38 was the voltage needed for my 2500K@4.8 to be able to Run IBT tests without failing .
so the options that i have are as follows ...
1- Fixed Mode => Vcore 1.42 + Level 3 Vdroop
2- Fixed Mode => Vcore 1.38 + Level 2 Vdroop
3-Offset Mode => +0.015 + Level 2 Vdroop
4-Offset Mode => +0.035 + Level 3 Vdroop
when running IBT & Hardware Monitor , the CPU will run @ 1.38V when stressed , so i wanted to know if there;s any difference between these setting ( since they all result in the same 1.38 ) and wich one should i keep , Thanks !
3 answers Last reply Best Answer
More about fixed mode offset mode question
  1. Best answer
    it's a different Load Line Calibration (Asus boards ),i assume you have Asrock or GB board (Level) which is there to combat Vdroop
    read this ,it should explain few things
    http://www.overclock.net/t/1219588/offset-mode-overclocking-starter-guide-and-thread
  2. i didn;t know that C"x" CPU technologies had effects on SSD Performance !
    Very Helpful link indeed , thanks
  3. Best answer selected by SkyWalker1726.
CPUs Overclocking
