My son’s system is:
Asus M4A78 Plus
Athlon II X2 250
AMD retail cpu cooler
Sapphire HD4830 video card
2 - 2GB OCZ PC2 6400 "SLI Ready Edition" DIMM's
2 - 160GB SATAII Barracudas
Thermaltake TR2 RX-450 power supply
Sony DVD burner
Airlink 101 Super G wireless PCI adapter
ECS card reader
Combo floppy drive (disconnected)
generic tower case
This evolution has been running 32-bit XP Pro with no problems for the past few months. A few settings in BIOS or some of the ATI Catalyst Control Center adjustments might have been tweaked, but nothing was over-clocked. (I blew out the old power supply letting the video card setup utility see what the optimal settings should be.) I installed 64-bit Windows 7 as a dual boot setup a few days ago with no problems. However, there was no driver that I could find for the wireless card, so there was no internet access. I found some 64-bit Asus drivers and left the system while it was extracting the contents of one of the zip files. When I returned, the system seemed dead.
Power lights on the case, the psu, and the mobo are all on and a light on the video card and the keyboard lights were flashing. A cold start will not even POST, but the fans and lights work. I tried clearing the CMOS, several times, swapping around the memory, disconnecting everything except the CPU, and the results were the same. The keyboard lights (on a year old HP multimedia keyboard) were flashing in what seemed to be a random pattern -- up to 6 times in a row. An old IBM keyboard would not flash more than once at a time, at a longer interval. On the chance that the keyboard flashing was similar to a beep code, I searched for some explanation and found nothing. I contacted Sapphire tech support to see what they could tell me about the flashing light on the video card, which is labeled "over heat protect," and they said to RMA the video card.
To get by while waiting for the turn around, I bought a Galaxy GeForce 210, with the intent to put it in my system later. The new video card made no difference – the system still won’t POST at all. I hooked up a pair of speakers to see if there was a beep code that I couldn’t hear through the system speaker, and there was nothing.
I have a lot of spare parts, but just not the right ones to determine exactly what is wrong, so I took it to a computer shop to have then diagnose it. I think that I can trust them, but I’ll have to see what they say.
Any thoughts on what the problem is?
Asus M4A78 Plus
Athlon II X2 250
Sony DVD burner
ECS card reader
generic tower case
