You could probably get away with a GOOD 650w PSU. But I'd probably go with a 700-750W since not many 650's come with (4) 6 pin PCI-E cables. It also depends on the rest of your system. If you have a highly OCed CPU, I'd stick with the 700-750. IF you are all stock a 650 would be plenty. Just remember you have to take in account the rest of your rig. This is what I would use, some people may say you can use a 550-600, but I always try and stay above the system requirements. Anything over a 750 will just be pointless.
^Indeed I did mean that. I've found the good quality 600-650W PSUs generally run close to a 700-750 price anyways. I ended up getting my PC Power & Cooling 750 for $90 after rebate. I think it was a $30 MIR. I was looking at a good 650w and I think it was around $100 anyways.
------------------------------Big Brother Rules with an Iron Fist
Reply to jay2tall
I have the corsair TX650 and a 5850...will I be able to use molex to pci-e adapters to crossfire later? Everyone says not to use them(molex to pci-e)...why?
Message edited by XD_dued on 11-10-2009 at 04:29:22 AM
I think that PSU should be ok. 52A on a single rail should be able to feed it. As long as the rest of your system isn't crazy power hungry with tons of drives.
You can use the molex to pci-e adapters. I would split the 6 pins and use one on each and then an adapter on each. It might be a good ideal to use molex connectors that are on a separate segment than your other devices as well. Just in case the card starts pulling some juice.
Reply to jay2tall
