Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help with a solid gaming rig I want to build in a few months
Forum Homebuilt Systems : New System Build - Help with a solid gaming rig I want to build in a few months
APPROXIMATE PURCHASE DATE: Anywhere in the next 3-4 months
BUDGET RANGE: Under $2K, but flexible
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming!!!
PARTS NOT REQUIRED: Starting everything from scratch
PREFERRED WEBSITE(S) FOR PARTS: I have experience with newegg and tigerdirect, but open to suggestions, I also have a Fry's Electronics in my hometown of Las Vegas
COUNTRY OF ORIGIN: USA Baby!
PARTS PREFERENCES: I'm leaning to the Intel i5
OVERCLOCKING: Sure
SLI OR CROSSFIRE: Yes, down the road when whatever I start with looses it's "edge"
MONITOR RESOLUTION: What ever monitor I get, but I have a 32" HD LCD TV I can use
ADDITIONAL COMMENTS:
Defiantly wanna try out the Swiftech H20-220 Kit;
Want a good power supply that would handle potentially up to 3 crossfire cards;
Good, fast RAM;
Direct X 11 ready;
Considering a 30-60ish GB(?) Fast SSD RAID Array for the OS, and maybe an additional 1TB drive for storage;
Would like a sleek, clean, elegant looking Mid ATX case that can house and cool all this.... The Panzerbox has caught my eye
Maybe a good BlueRay/HD DVD burner down the road
MoBo with good overclocking ability and Crossfire capability
I've been out of the computer building/gaming loop for a few years, but have built about 7 computers in the past. I remember my first comp I built in middle school and it was HOTTT thanks to it's sweet Voodoo2 video card! I'm amazed at how far the computer industry has come with affordable ready to go water-cooling kits, pre-modded cases, and LED.... well, LED EVERYTHING!!
Anyhow, I currently find myself deployed to Afghanistan and time in the barracks has re-kindled my past love of gaming! I have decided my coming home gift to myself is going to be a kick-ass gaming rig. I'm due back in the States in about 4 months time and would like to start accumulating parts now so I don't have to drop a 2000 dollar purchase all at once. Hopefully, that time cushion will let a few of the more expensive parts like the new ATI 5xxx series comedown in price, and I can buy them last. I don't have to have absolute top of the line everything, but I do want a computer that won't be outdated the first time I power it up.
I'm open to any suggestions, so lemme have it!
Thanks,
Logan
Sponsored Links
Welcome to the forum! Here's a possible build for you to look over:
Intel Core i7 860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core
http://www.newegg.com/Product/Prod [...] 6819115214
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel
http://www.newegg.com/Product/Prod [...] -_-Product
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop
http://www.newegg.com/Product/Prod [...] 6820227478
XFX HD-585A-ZNFC Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
http://www.newegg.com/Product/Prod [...] 6814150442
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal
http://www.newegg.com/Product/Prod [...] 6822152185
Intel X25-M Mainstream SSDSA2MH080G2C1 2.5" 80GB SATA II MLC Internal
http://www.newegg.com/Product/Prod [...] 6820167016
Antec TruePower New TP-750 750W Continuous Power
http://www.newegg.com/Product/Prod [...] 6817371025
LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower
http://www.newegg.com/Product/Prod [...] 6811112239
Pioneer Black 8X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 8X BD-ROM 4MB Cache SATA Internal Blu-ray
http://www.newegg.com/Product/Prod [...] 6827129037
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve
http://www.newegg.com/Product/Prod [...] 6835103065
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
http://www.newegg.com/Product/Prod [...] 6832116754
ASUS VW246H Black 24" 2ms(GTG) HDMI Widescreen LCD
http://www.newegg.com/Product/Prod [...] 6824236049
That's still under your budget and certainly qualifies as a "kick-ass gaming rig" ;)
If you have any questions, fire away.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Thanks for the super fast reply!
That CPU cooler is a beast! Do you think it would do better than the Swiftech H2O kit I mentioned?
That looks like it definitely would be a good build
Reply to baddestmofoalive
It won't be better but I'd still recommend it over the water cooler unless you're doing insane overclocks or are super annoyed by moderate fan noise...
Here's a review of the Hyper+
http://www.frostytech.com/articlev [...] 419&page=5
Reply to jbakerlent
Well that does sound like a good option and I will keep it in mind. Are there any new things coming out like new features or new generations of components that I should either:
A. Wait for because I will want to get them?
-or-
B. Wait for because they will drive prices of existing hardware down?
Yes, there are always new things on the horizon and prices will drop eventually, but if you need a new computer just buy it and don't worry about it imo.
Reply to jbakerlent
Within 1 month p55 mobos with usb 3.0 and sata 6 Gbps will start hitting the market. I suggest you wait for that.
Reply to itisravi
That sounds like a good call. Thanks itisravi
No, there's no need to wait. Buy the computer when you need it and don't worry about future changes too much (obviously if you don't need it now, hold off til you do). It's way to easy to drop in a $20 PCI card with a bunch of SATA 6 ports on one side and a bunch of USB 3 ports on the other ;)
Reply to jbakerlent
Purchasing parts over a long period time is a very bad Idea. If a defective part comes in, you won't be able to know about until your entire rig is assembled and if it turns out to be defective your return back time might already have expiried leaving you with an expensive but broken part that you can't do anything about. thats why purchasing everything all at once is the best. unless new egg has a very long return back time or something then don't do it.
Reply to blackhawk1928
^Agree, didn't see that sentence in the OP's post.
Reply to jbakerlent
Gotchya... save up, wait for USB 3.0, buy at once in case DOA/Defective parts. Thanks for the words of advise!
And by then more DX11/revisioned/oc'd, etc. cards will be out as well
But since you are looking at doing 3x crossfire/sli I would go with an i7 920 personally
Reply to cades
There are 1193 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
