Lower CPU speed gives higher FPS HELP!!!!
Related ressources:
- ForumHigher FPS with lower CPU speed ? WTF
- ForumMy 512MB Nvidia GTS 250 gives higher frame rates in Witcher 2, then my 1GB HD695
- ForumLower than expected FPS
- ForumGetting Lower FPS in SLI than I was with Single GPU
- ForumCPU that gives better performance then i5 3570k in GAMING PLEASE HELP
- ForumINTEL overclocking guide
- ForumWill i expect a higher performance using a lower type CPU ?
- ForumShouldn't my FPS be higher ?
- ForumWhy lower FPS when I OC?
- ForumWhy the more I overclock the lower FPS I get?
- ForumEvga GTX 570 classified higher Overclocking... Lower FPS
- ForumExplanation for i7 higher fps using sli/cf?
- ForumLower end PC outperforming my Higher End PC? [Need Help ]
- ForumDoes anyone think that AMD should release a lower power FX CPU ?
- ForumHigher CPU OC VS Higher RAM OC
- ForumHelp FPS is getting lower
- ForumLower FPS with 8800 GTS as dedicated PhysX card.
- ForumCrossfire HD7870 x8 questions?
- ForumHelp overclocking a 960t on an Asus m4a87td-evo
- ForumA8 3870k overclocking pls help
- More resources
Read discussions in other Overclocking categories
