Solved
Building Pro-Audio PC for first time, are these components compatable?
Hello, after long extensive research and realizing that I have to build a PC from scratch, I've come up with the below items to build my Pro-Audio dream PC. It appears that everything should be compatible, and that I shouldn't run into any issues, but just to be on the safe side, I'm putting it out there on Tom's hardware trial!
Tascam US 1641 interface
Here is the spec. Please tell me if anything jumps out as a red flag. This should be everything I need!
CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Item #:N82E16820145184
Antec Sonata III 500 Black Computer Case
Item #:N82E16811129024
ASUS VH192D Black 18.5" 5ms Widescreen LCD Monitor
Item #:N82E16824236070
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04
Item #:N82E16827106289
Seagate Barracuda 7200.12 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
Item #:N82E16822148395
GIGABYTE GeForce 8400 GS GV-N84S-512I Video Card
Item #:N82E16814125289
GIGABYTE GA-EP45-UD3R ATX Intel Motherboard
Item #:N82E16813128359
Seagate Barracuda 7200.12 1TB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
Item #:N82E16822148433
Microsoft Windows XP PRO Service pack 2 (free and this is the system my OS is optimized for, although I'm wondering how much of a difference there is between service pack 2 and 3).
Intel Core 2 Quad Q9550 2.83GHz LGA 775 95W Quad-Core Desktop Processor
Item #: N82E16819115041
ZALMAN 9500A 92mm 2 Ball CPU Cooler
Item #: N82E16835118223
7 answers Last reply Best Answer
More about building audio time components compatable
  1. Everything here is compatible.
    But you don't need the Zalman cooler because the CPU comes with one.
    And you can download the Windows XP SP3 through Windows Updates for free.
  2. Looks good to me.
    Don't forget a high quality 500 to 550 watt power supply for the system.
    Corsair, PC Power & Cooling, and Seasonic are some of the brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty. Lately we've been seeing a few other brands offering some high quality units. One example would be the Antec Earthwatts series which is a major improvement over Antec’s older psu’s like the Basiq models.
  3. Best answer
    Everything here is compatible with the motherboard/windows xp sp 2. As said earlier Window's Service packs are free for those who pass Windows Genuine.
    A good power supply is in order as Johnny Lucky has said: Corsair, PC Power & Cooling (Higher end options), and Seasonic are great power supply companies. I would also recommend OCZ PSU's in there as their OEM is PC Power & Cooling, (OCZ acquired the company PC Power & Cooling) in 2007). For your particular setup good quality 550w should more then suffice even at 100% 24/7 peak load although I wouldnt recommend doing so for over 1 day straight, not so much for the PSU's sake but for your component's..
    A few power supplies from Corsair are OEM from Seasonic although they also used Channel Well (CWT):
    CX-400 – Seasonic
    VX-450, HX-450 – Seasonic
    X-520, HX-620</a> – Seasonic
    TX-650 – Seasonic
    HX-650 – Seasonic
    I could recommend:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
    TX-650w Corsair PSU OEM by Seasonic. I was going to recommend the VX-550w Corsair (OEM Channel Well) but it was at 79.99+5.99 shipping this one is $89.99+ free shipping so for like $4 more you get a bit more bang for your buck. Comes with a $10 MIR as well.
  4. AsAnAtheist - You are correct about OCZ acquiring PC Power & Cooling. However, PC Power & Cooling does not manufacture any power supplies. All of their Silencer psu's are made by Seasonic. All of the Turbo-Cool psu's are made by Win-Tact.
    It gets kind of crazy with OCZ. Their power supplies are manufactured by Channel Well, Topower, Sirtec, FSP Group, 3 Y Power, and Impervio.
    I've got a brand new Seasonic X-650 Gold Certified modular psu in my new build. :)
    Yeah I have been let known that already. Interesting stuff. Thanks.
  6. Thank you all for your assistance! I actually needed to tweak the components a little and go with a fanless Radeon video card because my interface had a wierd compatability issue with nVidia products, and also my Sonata III comes with a 500w EA supply. In pro-audio, the Zallman fan is amoung the highest rated, and is needed to prevent over heating assoicated with long running times.
    Thanks!
  7. Best answer selected by gburgio.
Power Supplies Components Product
