Basically i currently have a xspc rasa 750 rs360 but plan to do some upgrading in the future most likely another rad. Now my question is what case would best suit at least for now the rs360 rad internally as i currently have the haf 922 and its simply not big enough. So far i have found the following cases but im open to suggestions although my budget is $150-$200.
Storm Trooper
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
Haf x:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
NZXT Phantom:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
NZXT Switch 810:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146089
These are a few of the cases that i found im not limited to just these so if you have any suggestions that are within my $150-$200 price point let me know. I know the switch 810 should be the best out of them but im not a fan of the look. I Also need 4 5.25 bays available along with the rad installed. Im also not looking to mod any of the cases either so if they require modding count me out.
Storm Trooper
Haf x:
NZXT Phantom:
NZXT Switch 810:
