Tom's Hardware > Forum > Graphic & Displays > Nvidia > Connect power supply dell 670 to gtx 260
Forum Graphic & Displays : Nvidia - Connect power supply dell 670 to gtx 260
the install instructions for the gtx260 into a Dell 670 call for two 6 pin connectors from the power supply. I have only one. There is another cable with a 4 pin connector that will adapt to the card. Does anyone know if that will work? Thanks
Sponsored Links
You will use one 6 pin and for the 2nd you should have an adapter that turns 1 or 2 4-pin molex power connectors into a 6pin. Most cards come with at least one. If not you will have to get one. If you have computer buddies they should have one or so laying around, I have a fist full. haha.
Message edited by jay2tall on 11-11-2009 at 02:19:30 AM
------------------------------ Big Brother Rules with an Iron Fist
Reply to jay2tall
There are 1083 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
