please tell me which power supply should i bring for Nvidia geforce 9800GTX+ for best results. I tried ocz modxstream-pro700 but unfortunately it didnt support .
Try getting a decent antec, or Corsair PSU or a seasonic or a gigabyte PSU.
I notice that you live in India. Maybe you should try www.techenclave.com and www.erodov.com Just register and go to forums>Dealers section. You should see some sellers selling the aforementioned PSUs. Buy one. 450 to 550W PSU should be enough from the aforementioned brands.
"ocz modxstream-pro700 but unfortunately it didnt support" Please clarify that what was the issue.
I have extactly that VGA and i am using Chieftech 650W and it is working like a magic.
------------------------------AMD Phenom II 720BE, ASUS M4A78T-E, 4GB Transcend DDR3 1333MHZ, Powercolor 4870 1GB DDR5, Corsair 750TX, WD 1TB Green, Maxtor Basics 500GB, Logitech G9x, Wolfking Warrior keyboard, Samsung 2233SW, CM Elite 33x, XBOX 360 Controller for Windows
iPOD Nanoch
Reply to hellraiser06
THANKS , MY PROBLEM WAS SOLVED ONLY BECAUSE OF THIS HELPING SITE & WITH YOUR ADVISE.
MY SYSTEM IS RUNNING SMOOTHLY NOW. THANKS ONCE AGAIN
M.ASLAM SRINAGAR
