Hello everyone, after 2 days of dealing with this forsaken problem and not finding an solution i wanted to ask before taking it to a technician...
Here we go...
Couple of days ago everything was working fine, but then the pc started acting strange, freezing now and then, i had to turn it off manually ... after that when booting back it hanged on the windows loading screen after trying several times it finally booted but once again i got the same issue...
Well i thought my windows was damaged so i formated the drive and erased the 2 partitions it had, i had it this way for couple of years. So after formating the drive i made a bootable windows 7 usb from my laptop that runs ubuntu using Unetbootin..
I put the usb on my desktop and it booted fine, i ran the installation with all the default values but on the part where it expands all the files it said that there were some missing installation files, which i was sure they were not but i started everything again to make sure. Made the usb again and tried installing, but no luck i had the same issue. i also tried installing ubuntu but i had no luck either it fails when selecting and installing software.
I'm thinking is the HDD thats dead, but it's fine in the bios, the drive have never being out the machine, neither have fallen or anything like it, there's no clicking sound either. But that's what seems to be the problem.
So i went on and tried some other stuff, i didn't have a dvd rom for a long time so i tried putting one in but is not being detected i tried changing the jumpers to different setting and no luck....
Well finally i wanted to give another try and installed a live ubuntu to the usb
but it wont boot either it stays at the syslinux screen, it seems like is going to but it hangs there...
So i really dont know what the problem is, i tried the usb on my laptop and it works fine...
What do you guys think? is it the HDD? or the mobo? or both or anything else?
Please lend me a hand to see what should i do, maybe i dont have to take it to anyone...
Thank you..
Here we go...
Thank you..
