Solved
Case air flow
okay im wondering if adding a side 120mm intake would help out with some extra airflow. my current setup:
Breakdown:
120mm-44CFM Front(lower) Intake
1-140mm Silenx 48CFM Top Exhaust
1-140mm Coolermaster 60CFM Top Exhaust
1-120mm Silenx 74CFM Rear(top) Exhaust
Here is the case with arrows drawn to show air flow. I suck with paint, btw.
with all the outtake is that a bad thing? my temps are pretty good. just wondering if there is too much negitive?/positive pressure. and if adding a side air fan would help even it out a little.
2 answers Last reply Best Answer
More about case flow
  1. Best answer
    I'd put another fan for intake to help with the positive pressure. I try to keep mine slightly positive so it's not pulling air through weird holes in the case. Positive pressure can 'direct' air better IMO.
  2. Best answer selected by viper979.
Heatsinks Silenx Cases Cooler Master Overclocking
