SLI problem
Hi, i am having problems running cod4 when using sli, i keep getting horizontal lines across the screen and flickering. My specs are..
- DualCore AMD Athlon 64 X2, 2200 MHz (11 x 200) 4200+
- Gigabyte GA-K8N-SLI
- 3072 MB (PC3200 DDR SDRAM)
- two x NVIDIA GeForce 7900 GT/GTO (256 MB)
- corsair tx650
- vista ultimate 32 bit
I am running the 191.07 nvidia drivers.
Please can someone tell me how to solve this issue, thanks.
10 answers Last reply
More about problem
  1. Hello :)
    Does it work OK with SLI disabled ? also have you tried any other games ?
  2. Within CoD4 there is a graphic option for SLI.
    Also, reset your NVidia Control Panel to default settings under 3D performance.
    Try to underclock both cards slightly to the same speed. If that fixes the problem, then you know one of your cards is starting to show its age, possibly the video RAM starting to fail.
  3. Hi, yes it works fine with either one card individually and cod4 is the only game installed on this pc. I have managed to reset to defaults but i am new to this so can you please explain to me how i can underclock my cards, thanks.
  4. Try EVGA Precision. Your videocards don't have to be EVGA brand.
  5. Ok iv downloaded EVGA precision, what shall i do?
    GPU 1 - core clock 500 - memory clock 750
    GPU 2 - core clock 450 - memory clock 660
  6. Try setting the clock speeds of GP1 to match those of GPU2.
  7. Thanks a lot iv tried asking all over the place about this problem and so far so good with matching the clocks, i really appreciate your help. Can i just ask what resolution could i go upto with these cards and is it possible to test if sli is working correctly?
  8. What res are you running at?, I found 12 x 10 was best. In nv control panel go to 3d settings and enable the SLi indicators and then run something like 3d mark.
  9. I have been trying it at 12 x 10 upto 16 x 10 i was just curious whats the highest res i could get out of running these cards in sli. I enabled the indicators and the green bar varies size alot.
  10. Let's just not yet start toying with the highest possible resolutions. Start with one of the lower resolutions. Work on fixing the flickering problems first.
    You might also need to downgrade or use earlier drivers since your videocards are nearly extinct.
Graphics Cards SLI Nvidia Graphics
