Someone Help me About Power supply ????
May 3, 2010 1:55:47 PM
whether the right motherboard 4 pin connector can use a power supply with 4 pin connector?
I have a asus mainboard p5kpl-am se, about what power supply compatible with my mainboard, but with 650 watts?
because I want to buy hd 4870,
thx,
More about : power supply
a c 156 V Motherboard
a c 144 ) Power supply
May 3, 2010 3:45:00 PM
Any ATX PSU will work. You need a 24 pin main power connector, 4 pin CPU power connector, and two 6 pin PCIe connectors.
PSU's generally have either a "4+4" plug that separates into two 4 pin plugs or separate 4 and 8 pin plugs.
Something like a Corsair 550VX (41 amp 12 volt rail):
is all you need.
A Corsair 650TX (52 amp 12 volt rail
would let you upgrade to any CPU and any single video card.
