Tom's Hardware > Forum > Graphic & Displays > ATI > HD4200 integrated problem
Forum Graphic & Displays : ATI - HD4200 integrated problem
I have an MSi 785e-65 motherboard with an integrated ati HD4200 video card.when i try to instal it on windows xp it seemes that the driver on Cd it s not supported.
Error: Ati catalyst it s not supported by the driver version of ou r enabled graphics adapter
Ati catalyst cannot be started because the currently GPU it s not supported
thanks
Sponsored Links
Try downloading the latest driver from AMD's site:
http://ati.amd.com/support/driver.HTML
Reply to Maziar
Well i downladed last night this driver and still not working.I don't understand: The driver on CD shouldn't be the correct driver fot this product?...i want to try today to instal windows wista and see what's happening.It's possible that this error apear only on xp?...
there are settings that must be made in bios?...
Reply to Anonymous
- 0 +
Well the driver on support CD should have worked,try with Vista and see if it helps however make sure you download/run the Vista version of Catalyst driver
Reply to Maziar
Ok,
Thank you very mutch.talk later and see what's happening
Reply to Anonymous
hi
probably graphics driver support onle windows vista or later (windows 7)
please install windows vista or 7
Reply to saeedxfx
- 0 +
I built a machine in Sept using an ASUS board with 4200 integrated graphics and XP Pro with no problems. I suggest installing the most current MB drivers and contact MSI if that doesn't help.
Reply to ram1009
i have same problem with mihais..my graphic card hd 4670..i instal OS (XP) but doesn't support..my mmonitor screen goes blank..but XP still running,i can't see anything..then i change my OS to Vista..mmy screen goe normally but i can't play some games such Football Manager 2010..
i need help...!!!
Reply to Anonymous
I resolved:)..i installed vista today and it works very good.Today i will install Windows 7.I hope it will work fine.
I thik there was a problem with CD driver for XP.
Have a nice day
Reply to Anonymous
- 0 +
Glad its fixed,its strange though that the driver with the CD has problems and you can't install it from AMD either,hope it will work with Win7 too ;)
Reply to Maziar
There are 561 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
