PARTS PREFERENCES: Parts that I plan on getting are:
CPU Intel Core i5 750 2.66ghz Quad LGA1156
MoBo ASUS S1156 P7P55D Deluxe Core i5
RAM DDR3 4GB G.Skill Trident 1600mHz PC12800
HDD WD 800GB AADS SATA 7200rpm w/ 32MB
Video Card Gigabyte ATI Radeon HD5750 1GB PCIe
Case Antec Nine Hundred 2 Black Case (No PS)
PSU Antec TruePower 650W TP-650
Optical Drive LiteOn 24x DVD Writer SATA BlackĀ
Network Card D-Link DWA-556
OVERCLOCKING: No
SLI OR CROSSFIRE: Crossfire comes with the Video Card (help?)
MONITOR RESOLUTION: 1280x1024
ADDITIONAL COMMENTS: Is this system configuration correct? Will the 650W PS be enough for the system? and most of all will it fit into the case?
Message edited by aussie123 on 11-04-2009 at 11:00:34 AM
The psu is more than powerful enough.
For gaming, the graphics card might be a little weak. There are cheaper and equally good cases than the 902 (antec 300 for example, or even the sonata III, which is truly a bargain for its quality). You could save a little bit on the mobo and a network card is usually integrated in the motherboard. With the money saved, you could buy a 5770 or even a 5850, which will greatly improve your system.
You should also consider a Samsung spinpoint F3 as a HDD, it's easily the best price/performance HDD on the market today. It's fast, cheap and cool.
BTW: crossfire is putting two ATI graphics card in one pc, so you'd need to buy 2 cards to use it.
You wouldn't notice a thing, I guess. Such expensive mobo's, like the Deluxe, only seem to be helpful in crossfire solutions, not to mention that even a cheap Asus motherboard already means good quality.
If I don't plan on oc'ing the CPU, is the stock heatsink that comes with the Core i5 750 sufficient? Or should I get a good aftermarket heatsink anyway just to keep the CPU cool?
btw looking at getting a Noctua NH-U12P heatsink, if I do buy one.
With the stock cooler, you can get a tiny bit of overclocking with some luck, but it's not sufficient normally, certainly not for the real thing.
You need an aftermarket cooler. These things go from $20 to insane amounts. Ask yourself this: 'Do I want to give it a mild overclock, or do I want to squeeze every bit of power out of the bloody thing?'. In the first case, a decent entry level cooler is enough, if not, get something bigger and better.
Can't tell you much about that model, but it has a reputation for being silent and giving you enough room for some moderate overclocking.
Than the stock cooler is fine. The only thing an aftermarket cooler has in that case, is that they sometimes are a little bit less noisy. So no, there's no reason to get one if you're not overclocking.
