flyingtitan said:
i plan on using windows 7 for the OS. would that still work with 8gb?
Only if it's 64-bit. A 32-bit OS can't even fully use 4GB of RAM. 8GB of RAM is complete overkill, but go ahead and get it if you want. Just make sure to use a 64-bit OS.
The fact that you don't game and are only interested in a single graphics card changes the build suggestions considerably. Here's a suggested build for you:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... $243.98 (CPU + RAM combo)
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail
Antec earthwatts EA430 430W Continuous Power ATX12V v2.0 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... $106.94 (Case + PSU combo)
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $74.99 - $10.00 MIR
GIGABYTE GV-R575D5-1GD Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $144.99
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $87.99
SAMSUNG HD103SJ 1TB SATA 3.0 7200 RPM 32MB Buffer Hard Drive Bulk
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?Product... $92.99 - $15.00 MIR
Sony Optiarc Black 24X DVD Burner
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... $129.98 (DVD burner + OS combo)
ASUS VH222H Black 21.5" 5ms HDMI Widescreen 16:9 Full HD 1080P LCD Monitor Built in Speakers 300 cd/m2 1000:1 (ASCR20000:1) w/ SPDIF out - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $159.99 - $10.00 MIR
Total - $1,041.85 - $35.00 MIR's
