Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power my system... will it be enough..?
Forum Graphic & Displays : Graphics Cards - Power my system... will it be enough..?
Hey there everyone, how u all doing.:) i have a few questions regarding power i want to find out about.
I have a 500W but i can get my Hands on 550W power supply, i was wondering if i could run a ATI Radeon 4890 1gb GDDR5 Or NVIDIA Geforce 275 896MB DDR3 Edition- XFX/Sparkle with the following components,
Processor : AMD Athlon 64 X2 5600+ 2.8GHz Socket AM2
RAM : 3Gb DDR2 Kingston 800MHz
Hard Drives : 2 x 500gb SEAGATE (internals)
Motherboard : ASUS M2N-MX SE PLUS
DVD Writer : LG SATA DVD Writer
Case : Nitron Blue with 3 extra fans.
I was wondering is that enough power or will my system like blow up or something:):)
Would be extremely great if you could provide me with some help for my problem:)
Nash.
Sponsored Links
Can you give the specs of the two PSU's? THe difference in a 500 to a 550 depends on the make and model. There is MUCH more to a PSU besides it's wattage rating. But if either is a half decent unit, you will be fine.
------------------------------ Big Brother Rules with an Iron Fist
Reply to jay2tall
okini wrote :
your ram sucks to be 100% honest with you but your CPU is fine. Get 6GB DDR3 ram and you will squezze out some extra fps with either of those cards. IMO you should go for the GTX275^^
That might work, of course he'll have to file a new slot in the DDR3 ram to make it fit into the DDR2 slots on his motherboard, oops guess it won't work.
Reply to Delluser1
Seriously, you need to stop with the negative comments. This is not a forum that tolerates negativity, especially toward newcomers.
To the OP: your RAM is fine. Unless you have a 64-bit OS it won't even see more than 4GB (plus you loose some memory mapping with a video card, so usually you can't see more than 3GB anyways on a 32bit OS). So not worries. Plus the suggestion was for DDR3, which your motherboard only supports DDR2. So that is an inaccurate suggestion anyways.
As far as the video card suggestions. The 4890 and GTS275 are direct competitors. I assume you will use this for gaming, so the best suggestion is to look at some reviews and see which card performs better for the games you play. I'd still like to see what power supply specs you have.
Message quoted 1 times
Message edited by jay2tall on 11-12-2009 at 07:36:08 PM
Reply to jay2tall
- -1 +
negative???? dude i just helped that guy. Ok his ram is fine but 3GB DDR2 wtf. Thats not enough. He would get better fps with a 6GB DDR3!
Reply to okini
- 0 +
While that may be true, his mobo will NOT support DDR3 Ram, so your suggestion is without value... :ange:
Reply to clarkjd
He would have to upgrade his motherboard to install DDR3 memory. Also, more than 3GB most likely would not be recognized by his OS unless it is 64bit. Also, AMD chips have showed to show minimum benefit between DDR2 and DDR3 in gaming. Below is a test in crysis between the two. Although it is on a Phenom II platform, the results should be comparible with an Athlon 64 x2 system.
http://www.tweaktown.com/articles/ [...] dex11.html
Increasing the amount of memory would also not show a benefit unless he was capping out his physicall memory usage and his OS starts to use virtual memory. Im most cases though, it will load the items being used in physical memory (ie the game), and other items in virtual memory. It might have a slight impact on the game, but nothing major.
I think we need to address the OPs questions when he give us his power supply specs. The 4890 and 275 are pretty comparable with power requirements, so as long as his PSU is sufficient he is good to go.
Reply to jay2tall
Yes, it was negative, and wrong as well. I think you need to slow down a lil
------------------------------ I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
Considering his motherboard is DDR2 only, how will 6GB of DDR3 manage that?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
wow thanks for the quick responses.:) I have some Pro-case 500W and a cooler master 550 watt I'm not entirely sure what the amps or the voltage rail is? and about the ram most games these days only need like 2 gb max on the recommended side...
I have a 64x bit OS and my CPU obviously supports it so i think that should be fine my next step after the card will be getting a bigger PSU then motherboard and ram. But that's for the future.:)
Reply to Deathgod121
- 0 +
I don't know about the other one but Cooler Master is a pretty decent brand and I would think a 550w unit by them can handle those cards.
Reply to jyjjy
^I concur Dr.
I would trust the Cooler Master over the Pro-case any day.
Reply to jay2tall
okay well i think i will go for the cooler master then hey:) if u think it would work better because of the brand then i will use it:0
Thanks again so much for the help guys it was good info:)
#1 is is a 550 over a 500w.
#2 yes I trust Coolermaster over a ProCase, which I have never heard of.
Reply to jay2tall
haha, yep my friend has a procase external hard drive which is pretty good now all i need to is find a shop to get the card from?
- 0 +
You'll usually find better prices shopping online
Reply to jyjjy
Hey guys i finally got my card i ended up with the 4890 but the XFX edition:) on my 500 W it runs perfectly:) its a good i recommend it:)
There are 747 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
