Hi all:
I have a HP F50 LCD and I am using it with a ATI Redeon 7500.
I was using analog cable and the LCD works perfect. Couple monthes ago I put a DVI cable then here is the problem.
The display is distorted badly before the XP login page. That means from the computer start until the "black XP screen", half of the area is distorted. Once I get into the login page and after that the display works great. I can use it perfectly under XP but if I need to change something in BIOS, I have to use the analog cable.
There are a pair of Altec's speaker and a logitech's receiver around the LCD, I tried to put them away as possible but no works.
I tied the DVI cable with all rest of the cables. Does this has anything to do with it?
Or is it a bad LCD or ATI card?
