I have dual booted my system with xp (other is ME) and everything has worked very well. However, i tried installing nero on the xp partition, and it said i had an older version on my computer. So, i uninstalled nero from my ME side of things. However, even though its now gone from my computer, it still won't install because it thinks i have an older version still on meh comp. Any help would be GREATLY appreciated. Personally, i don't think it's XP, but you boys might know a fix for nero. Thanks.
if you uninstalled it from your me boot, and it also went from xp, it sounds like you installed it in the same place on both os's. I use 5.5 on xp and have had no probs- except when doing multiple copies and I insert the next blank, stooopid xp gives me a dum window asking what program I would like to use to open the files on the blank cd- which then causes nero to abort- easily solved by turning off autoinsert I suppose but I never got round to it.
