Hey guys. I have the weirdest problem. So my brother bought an Gainward HD3850, but since it was too loud for him he bought an Accelero S1 rev. 2. Until then the card worked flawlessly, but after he put on accelero the card stopped working. It doesn't send any signal, but you can feel it is working since it's heating. Weird thing is, he has a crossfire mainboard, and the card actually works on the second pcie port!! Well actually that isn't that weird 'cause you would think that the port is broken, but he borrowed me his card to try if it works on my computer. So i put it in, and it doesn't work. The difference is, my mainboard has onboard graphics and no crossfire, while his has crossfire support but no onboard vga. So, on my computer, when I put the HD3850 inside, the signal goes automatically to the onboard, like this one isn't even connected. So my question is: what the hell is wrong!? How come it works on his mainboard, but only on the secondary pcie port? And also, i tried to disable my onboard vga (Mainboard: Asus M2A-VM) to see what would then happen but I can't figure out how to disable it... Anyway, if anyone knows something or has a similar problem, please help... Thanks in advance xD
