Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > First System Build, Expert advice plz
Forum Systems : New Build First System Build, Expert advice plz
Hello Tom's Hardware, i have been Thinking about building a PC for an while now, and it took me a while to pick out all the parts. This will be my first PC build, and Basically i will be using it for gaming (Crysis, COD:5 and COD:MW2), internet, Movies and Videos. though, becaouse this is my first time building a PC i thought i Should get some expert advice from the community at Tom's Hardware. T
My Budget on the Setup is $1200. Though this is an whole setup, not just the computer:
(Note: Speakers are not included because i already have good well-working PC speakers)
Computer Custom Build:
______________________________________________________________________________
Motherboard+ CPU Combo:
CPU: Intel Core i5-750 Lynnfield 2.66GHz LGA 1156
MOBO: MSI P55-GD65 LGA 1156 Intel P55
($339.98)
http://www.newegg.com/Product/Comb [...] mbo.273134
CPU Fan: ARCTIC COOLING Freezer 7 Pro 92mm ($33.98)
http://www.newegg.com/Product/Prod [...] 6835186134
CPU Thermal Compound: Artic Silver 5 (6.95)
http://www.newegg.com/Product/Prod [...] 6835100007
RAM: G.SKILL Ripjaws Series Red 4GB DDR3 1600 ($87.99)
http://www.newegg.com/Product/Prod [...] 6820231277
PC Case: APEVIA X-TELSTAR-JR G-Type ($75.99)
http://www.newegg.com/Product/Prod [...] 6811144209
Extra Case Fan: APEVIA CF12SL-UBL 120mm Blue LED ($7.99)
http://www.newegg.com/Product/Prod [...] 6811998121
_______________________________________________________________________________
Graphics Card: XFX Nvidia GeForce GTX 275 896MB ($227.00)
http://www.ewiz.com/detail.php?name=XFX-G275CE
Hard Drive C: Western Digital Caviar Green 750GB ($69.99)
http://www.newegg.com/Product/Prod [...] 6822136359
Power Supply: hec X-Power Pro 650 650W ($44.99)
http://www.newegg.com/Product/Prod [...] 6817339024
Optical Drive 1 [5.25 Drive] :SAMSUNG Black 22X DVD+R ($29.99)
http://www.newegg.com/Product/Prod [...] 6827151175
Optical Drive 2 [5.25 Drive] :Sony Optiarc Black 24X DVDRW ($33.99)
http://www.newegg.com/Product/Prod [...] 6827118032
Optical Drive 3 [3.25 Drive] :Silverstone SST-FP32-B USB ($14.99)
http://www.newegg.com/Product/Prod [...] 6813999356
Sound Card: SIIG IC-710012-S2 7.1Channel 96khz (34.99)
http://www.newegg.com/Product/Prod [...] 6829270006
LCD Moniter: Asus VW192T+ 19 inch WideScreen " ($129.99)
http://www.ewiz.com/detail.php?nam [...] %2B&show=p
Mouse + Keyboard: Microsoft BV3-00003 Black 102 ($25.99)
http://www.newegg.com/Product/Prod [...] 6823109033
So this is the build ^ Whad do u think tom's Hadware? :D
Reply to TJ75
and BTW the Monitor is 1680 x 1050 and yes, there will be (at least attempted) Overclocking
Reply to TJ75
Welcome to the forum.
Why three ODDs?
The combo on the mobo/CPU expired, but I would get an Asus/Gigabyte anyways.
ASUS P7P55D PRO LGA 1156 Intel P55 ATX Intel
http://www.newegg.com/Product/Prod [...] -_-Product
I don't really like that case, but it's up to you.
Don't get that PSU
Antec TruePower New TP-750 750W Continuous Power
http://www.newegg.com/Product/Prod [...] 6817371025
Don't get that HDD
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal
http://www.newegg.com/Product/Prod [...] 6822152185
You most likely could skip the sound card.
Finally, consider the HD 5850.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Oh and this HSF
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long life sleeve
http://www.newegg.com/Product/Prod [...] 6835103065
You could likely skip the TIM, as well.
Reply to jbakerlent
Depending on the company I think you could get a 4890 with possible lower prices and higher if not comparable performance.
Also wondering if you'd really need two Optical Drives? The Sony one should be enough right?
Edit: Also, yes the third ODD, your case should have all the ports you need, unless you're going to jam pack the computer with USB components.
Message edited by Onyx2291 on 11-05-2009 at 01:41:34 AM
Reply to Onyx2291
If you're only running a single video card, I'd suggest this PSU.
http://www.newegg.com/Product/Prod [...] 6817341022
Most onboard sound is good quality now days, so I would drop the soundcard.
This would be one of my favorite cases around the same price
If you're running windows 7, I'd suggest looking for a 5850. If not, I'd suggest the ATI 4870 or 4890. They're much better price/performance.
4890 - http://www.newegg.com/Product/Prod [...] -_-Product
4870 - http://www.newegg.com/Product/Prod [...] 6814131148
With the $$ saved, you could upgrade your monitor to something like this
Acer 22"
http://www.newegg.com/Product/Prod [...] 6824009145
------------------------------ CM HAF 932 / GIGABYTE GA-EP45T-DS3R / E8500 @ 3.75Ghz / 300GB Velociraptor / 4G DDR3 OCZ Reaper 1333
Saphire 1G 4850
Simple and Free Guide to Removing Malware
Reply to aford10
Thanks for the Answers
Reply to TJ75
There are 2132 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$600 Budget Gaming Build - Advice Appreciated
By coffeecoffee, 4 hours ago:
Alright, your on the right track. There are a few changes I would like to make if I...
Best offers
Top experts
