Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power supply swap due to video card?
Forum Graphic & Displays : Graphics Cards - Power supply swap due to video card?
im looking at buying a Asus Essentio CG5270-BP004 with a intel X video card or something but im looking at replacing it with an Asus EAh4890/ 1gb and am wondering in the stock psu (300w) will be able to sustain it, and if not what will? Please help if you can
Sponsored Links
Definitely not.
http://www.newegg.com/Product/Prod [...] 6817341017
That powersupply is good for you.
------------------------------ "It could also be using the testicles of squirrels but until more is known it's all supposition and guess work, best to just sit back and wait."
-MouseMonkey
Reply to shadow187
^Agreed.
I prefer Corsair (Seasonic) PSU's but that has a better rebate and the damn Corsair PSU's are as out of stock as the HD 5870 these days.
Reply to TheViper
TheViper wrote :
^Agreed.
Because people like you keep buying them :lol:
-MouseMonkey
Reply to shadow187
Also wondering if ill need to add a fan in there so the card doesn't melt to the motherboard lol
Reply to wisher75
Every case should have a minimum of three fans.
2 exhaust fans blowing heat out the back of the case, and 1 fan blowing heat into the case from the front.
-MouseMonkey
Reply to shadow187
True, but i didn't know if it would be a good idea to upgrade them or not. I've been told yes and I've been told no. This is assuming that i don't plan on ocing it
Reply to wisher75
It all depends on your case, or if you want to buy a custom card, like below;
http://www.newegg.com/Product/Prod [...] -_-Product
-MouseMonkey
Reply to shadow187
so which card do you think is better? the asus EAH4890 or the Sapphire vapor-x? in a stock case no upgraded fans?
Reply to wisher75
Both kick most of their heat outside the case via a rear exhaust vent.
I've checked but can't seem to find any data on the included case fans. Does that Asus Essentio come with any fans? If not, you certainly need some just to have them for adequate air flow; high end GPU or not.
Reply to TheViper
There are 1503 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
