Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need Power Supply / Video Card
Forum Homebuilt Systems : New System Build - Need Power Supply / Video Card
Hey guys,
I'm building a new computer and I have all the parts however my power supply I chose is out of stock. I was wondering if anyone could help me find one like this power supply I have that is compatible and around the same price. I'm also looking for a video card that will last as long as possible and under $170.
These are my parts:
http://www.newegg.com/Product/Prod [...] 6811129066
http://www.newegg.com/Product/Prod [...] 6813131604
http://www.newegg.com/Product/Prod [...] 6817139004
http://www.newegg.com/Product/Prod [...] 6819115215
http://www.newegg.com/Product/Prod [...] 6820227478
Thanks
Sponsored Links
For the video card under $170 might I recommend a 5750 or 5770 for longevity, if you get lucky the 5770 can be right at the 170 mark.
Reply to Onyx2291
GPU
GIGABYTE GV-R577D5-1GD-B Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
http://www.newegg.com/Product/Prod [...] 6814125301
PSU
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC
http://www.newegg.com/Product/Prod [...] 6817371015
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Nothing really except price and brand.
I would recommend the XFX one if you're willing to pay above your $170 :)
Reply to Onyx2291
Is there a better card that will last longer for under $200? Im looking for something that will be able to run games really well in like 5 years.
Reply to googlexx
No, the 5xxx series right now is the newest and at the moment would be the longest lasting due to DX11.
The next step up is the 5850 at around $300 which is way over. Otherwise all I have to recommend is the 5770.
Reply to Onyx2291
There are 1131 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
