Tom's Hardware > Forum > Homebuilt Systems > New System Build > First Build, New System Build
Forum Homebuilt Systems : New System Build - First Build, New System Build
This is my first build. My first computer was a compaq presario in 2000. I bought a top-of-the-line HP laptop in 2004. Now I'm looking to build a machine for gaming that I can use for the long term and upgrade as needed.
APPROXIMATE PURCHASE DATE: This Week
BUDGET RANGE: $900 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, connecting to 50” HDTV for gaming
PARTS NOT REQUIRED: CD/DVD Drive, monitor, mouse, keyboard
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: U.S.
PARTS PREFERENCES: AMD
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Maybe in future
MONITOR RESOLUTION: 1600x1200 Monitor, or 50” HDTV
ADDITIONAL COMMENTS: My old (2000) desktop with a 40 gig hard drive – It ran Windows ME, I upgraded to XP – Can I use the old hard drive on it as a springboard in a new system so I can get a Windows 7 Upgrade instead of having to buy the full package, and if so, will copying the old HD to the new also copy the OS without problem so I can get rid of my old 40 gig HD after I have installed the Windows 7 upgrade?
The game I will be playing is "Gears of War," which I have had for a year but not had a good system to play it on. Given this, my build may well exceed the gaming requirements, but I want to be able to have good resolution on my 50" HDTV for this and other games.
QUESTION: I noticed in some builds they suggest using 2 less expensive cards instead of one better card. Would I be better served using the 2x Gigabyte GV-R485OC-1GH Radeon HD 4850 1GB (the same card that was used 4x in the $1250 build article)
Case
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Item #: N82E16811119137
-$15.00 Instant
$84.99
$69.99
Hard Drive
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136218
$69.99
GPU
HIS H489FP1G Radeon HD 4890 Turbo+ 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Item #: N82E16814161298
-$10.00 Instant
$10.00 Mail-in Rebate Card
$199.99
$189.99
Power Supply
OCZ GameXStream OCZ600GXSSLI 600W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
Item #: N82E16817341001
-$50.00 Instant
$20.00 Mail-in Rebate Card
$129.99
$79.99
Memory
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
Item #: N82E16820231193
$89.99
Combo
Combo
• AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 140W Quad-Core Processor Model HDZ965FBGIBOX - Retail
Return Policy: CPU Replacement Only Return Policy
• ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard - Retail
Item #: N82E16813131402
-$35.00 Combo
$315.98
$280.98
Subtotal: $780.93 Tax: $64.43
Shipping: $33.86
Grand Total: $879.22
Sponsored Links
The build looks pretty good. I wouldn't mess with your old hard drive. You can just get the OEM version of Windows 7 which costs less than the upgrade and will allow you to do a fresh install. Here's a couple combo deals that might interest you:
http://www.newegg.com/Product/Comb [...] mbo.282078 $286.98 (64-bit Windows 7 + Sapphire 4890)
http://www.newegg.com/Product/Comb [...] mbo.282024 $261.98 (64-bit Windows 7 + Sapphire 5770)
This drive is faster and cheaper than the blue 640GB drive.
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $54.99
Here's a combo deal for the case and PSU you picked:
http://www.newegg.com/Product/Comb [...] mbo.291794
Reply to shortstuff_mt
Thanks shortstuff_mt! I have made all the changes you suggested. Regarding the Windows OEM, I didn't know what requirements I had to meet to buy the OEM version. The combo deals and Samsung drive are very helpful.
Reply to astrosausage
That psu should be pretty future proof http://tsutton.site90.net/imgs/signature_smiley1.jpg
------------------------------ Saving up for new ipod touch cant wait
Reply to admin123
Any person building their own PC can use the OEM version of Windows. That's all I ever use. Good luck with the build!
I had a CD-rw and a CD/DVDr drive on my old computer - Is there any reason I shouldn't use those for a new build?
Are they IDE or SATA? New motherboards only have a single IDE slot for a total of two devices. I prefer to spend the $30 on a new burner so I don't have a big IDE cable blocking airflow in my case.
http://www.newegg.com/Product/Prod [...] esult=True
+1
there's no need to be cheap with a $900 build. definitely get sata.
Message quoted 1 times
Message edited by overshocks on 11-05-2009 at 10:41:47 PM
------------------------------ You can select me as Best Answer
e6400 oc'd 3.2ghz,CCF cooler
3870x2, p5k/epu
750watts psu, antec 900
Reply to overshocks
They are way before SATA - Thanks for the suggestion - I added the Lite-On iHAS424-98
overshocks wrote :
+1
As far as my video card $, wouldn't getting two of these or similar be better than the 9870 I have spec'd?
MSI N9600GT-MD1G GeForce 9600 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
^well your resolution is 1600x1200, really you only need a 4870..or get a 5770(supports directx11)
there's no point getting 2 9600GT, they suck and wasting money.
3870x2, p5k/epu
Reply to overshocks
No, I would not get two 9600GT's. Your motherboard doesn't support SLI anyway, so that's not even an option. The 4890 is a strong card.
OK! I stuck with my 4890 and just placed my order - it came out to $922 before the rebates, which are $30, so that puts me just under $900! Well done! Thanks for your help!
Thanks overshocks for your help. I am very happy with my build now.
There are 882 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
